Help Required. Can anyone advise on playing .flv video files on HDT 500. Files are presently on SanDisc Flash Drive. Recorder appears not to identify files.
Message was edited by: Simpleton
Hi there
Funnily enough, I looked into this about a week ago for myself, unfortunatley external video files are not supported on the HDT500/1000 PVR recorders. The only file format supported are MP3 and JPG.
Cheers.
Thank you Quinnicus that saves me from wasting time experimenting.
Simpleton:smileywink:
