Is it possible to stream music from my Ipad to my Sony BDP-S6200 over my WIFI connection, and hence it will then play through my sound system or soundbar......and if so how do I set it up.
Thanks for any advice
Hi there
You need an app called iMediaShare.
Available on iTunes :
https://itunes.apple.com/gb/app/imediashare-personal-stream/id710578942?mt=8
These instructions should help you set it up:
In addition to what Quinnicus has mentioned above, if your sound system has AirPlay you can stream directly from iTunes on your iPad bypassing your BD Player altogether.
Some of the Sony STR range of receivers have this feature. I use it on mine quite a lot and it sounds pretty good!
