My Home theater main unit just says E2P INIT after power on and does not respond to any other butttons of the device (or remote) except power on/off. So I can turn it off, but when I turn it on it just says E2P INIT. The problem just started suddenly. Does anyone know what this message/code means and if there is something that can be done about it? Appreciate any help.
Hi there
I cannot obtain the service manual for your system, but it sounds like a hardware fault. The only suggestion i have is to try and reset the device. See instructions below. If that fails, you could try contacting Sony Support or contact a repair centre, but if it is a hardware fault, you are probably looking at a new system now as its likely to be un-economical to repair.
