Dear community,
I have several issues from time to time with audio format like AC3-DTS and 5.1. The amp dosen't playes the voices. I have all the other sounds exept the voices.
The last one was tricky...The video is played on a mac with vlc. It's a mkv container. Audio spec are :
- Container : Matroska
- Format : AAC 5.1 - MPEG-4 audio
- Profil d'encodage : Low Complexity
- Nbre de canaux : 5:1 - 6 canaux
- Position des canaux : Front: L C R, Side: L R, LFE
Changing audio parameters with vlc doesn't resolve issues.
Without tha amp, the audio output on the mac is perfect... when I plug the hdmi... voices disappear. All options on audio on the amp has no effect at all.
Any clue ?
Regards
Revillon
[Edited for privacy]
-EdU
That's a weird one, have you performed a speaker test to make sure your centre speaker is working? Do the voices come back when you use your televisions speakers?
