I use AirPlay on my STR-DN840 over wifi and it worked well, with the occasional loss of connection, but reconnected again.
Recently, I was watching the amp when the music stopped and the little wii / network symbol (button l/h side of display) went out. It as not worked since. I cannot get the network connection to work, either with wifi or hard wired Ethernet. When I go to Home / Settings / Network it just shows a screen sayin "Please wait" and nothing happens.
Everything else on he unit sees to work, but despite resetting it, and my router, I cannot get a network connection. Please help, I miss my music!
Well someone from Sony rang and told me that the receiver has to be sent away for repair. Disappointed as no diagnostics were suggested. I dont understand why this wasn't suggested at first. Off to find local repair centre...
Repair centre informs me that new network board / card needed. Awaiting return of unit.....
Thanks for the update - at least they seem to have found the problem and got a solution. Its just it takes soooo long !
Looking back, it might be more than just coincidence that the amp was relocated from an open, glass shelf TV stand to a partition in a wooden (ha) unit that has a solid back, and only open at the front. I'm beginning to think that heat build up might have led to the failure.
When end I get the amp back, I'm going to make sure there is more ventilation.
