Do we have a release date yet including suppliers?
On a technical note are any of the 4 analog audio inputs able to accept and amplify a phono input?
Hi there
I believe the release date is 'May'.
In regards to your question - I have attached the manual for you to read. Have a look at page 35 and maybe the specifications.
Thanks for the response and the manual, so by phono equaliser it looks like a pre-amp is required. No problem for me as my Pro-ject cable is too short and I needed to extend it in any case. In the wider picture considering the revival of vinyly maybe a trick missed but that's budget receivers for you!
