STR-DN1080 auto power on
profile.country.GB.title
eagleTV
Explorer
Hi, I have just puchased this. I have set it up to have standby pass through. I have set HDMI auto power off to "off".
However when I power on my Skybox, it turns the amp on. I don;t want it to do that.
I'm looking through the manual, can't see where this is covered, any help appreciated.
9 REPLIES 9
Anonymous
Not applicable
Hi there,
How do you have your set up connected?
Best wishes,
M
eagleTV
Explorer
Hi, Sky box into the Sat/cab input into the Amp via HDMI.
Amp to TV via HDMI, LG.
LG TV input is ARC friendly, and also has something called Simplink that recognises Sony.
Maxigooner
Explorer
Hi All,
was as this issue resolved I have the same issue at the mo.
eagleTV
Explorer
Sort of, it ultimately came down to my LG TV & it's settings sending a "power on" signal back to Sky but instead it was turning on the amp.
Maxigooner
Explorer
Okay, thanks.
profile.country.GR.title
68058468
Member
I have the same issue with LG Oled and STR-DN 1080. The receiver powers on every time the hdmi input of the arc is selected on the TV and the annoying home screen of the receiver pops-up after a few seconds. So the hdmi passthrou is not an option.
eagleTV
Explorer
I have the following.
Control for HDMI off.
eARC on
Standby Through on.
So the amp no longer powers on. Which is good. I can still watch Sky, my main viewing-passing through, also good.
Have to turn the amp on to watch any other input.
Works for me for now.
68058468
Member
Unfortunately, it seems that you must choose between passthrou and volume control. You can't have them both. Hdmi control to on gives you the ability to control volume with your tv's remote but passthrou does not exists as a notion then. Hdmi control to off does not power on the receiver (so you can passthrou signals) but you need the receiver's control to adjust the volume... Thanks sony! Can't use my smart remote thanks to you!
68058468
Member
Tested to disable hdmi control. The arc is not functional at least in my configuration...
