Hello, anyone setup two subs on this receiver. How did you set it up.
Hi Maxigooner,
I'm not sure about a 2 subwoofer setup but the information in this guide may help. Perhaps some other members will be able to give you some insights.
Best wishes,
Ed
Thanks for coming back end. I ended up playing around with the auto config and got two subs to work - works a treat. More richer thump plus with the virtual rear surrounds makes movies more immersive without shelling out a loud of money. Another satisfied customer.
How did you hook the 2 subs up?
The 2 subwoofer outputs on the back
I’ve hooked mine up to that on the amp and the LFE ON THE SUBS Or you could just connect to the red or white phono stereo plugs on the sub
LFE IS CONTROLLED VIA THE ANO AND NOT THE SUB
Hi, you mean you managed to plug 2 subs on your str-dn1080 and they work fine?
Hi @BazazBack
I just went through the Manual but I can't find reference to Safe Mode or any temperature related errors. There's just a warning that it may get hot on page 58: https://www.sony.com/electronics/support/res/manuals/4686/1a5e9c2b4143ad36dd5cb360f2a11851/46865241M...
Do you get a specific error code? For what it's worth, it seems to be within specs so there may not be anything to do about it apart from improving air flow.
Win_88
