Hi Shay,
Lucky you having a STR-DN1060, I only have the 1040 model myself! :((
This link will help you, there's several Bluetooth headphones to choose from. I believe you just pair the headphones with your new receiver to get it to work.
I can really only make an educated guess on this one but I would suspect that since both devices are 'new' Sony products the headphones will most likely have the Bluetooth transmitter built in, much like a mobile phone has. Having a seperate transmitter seems like old technology to me. Have you tried looking at the specifications or user manuals?
Incidentally I've just looked back at the link I provided earlier and this model has the following useful feature (shown in red below)
No cables, less distractions, more music MDR-ZX770BN
Around-the-ear wireless headphones with built-in Bluetooth and digital noise cancelling
NFC stands for 'Near Field Communication' which basically means that you touch the headphones against another NFC equipped device to pair the two together. In essence this simplifies pairing. You'll likely be pleased to know that the STR-DN1060 also supports NFC.
If you want to take a peak at the DN1060 Manual you can download them here: Manuals
The headphone model I refer to above is one of several Bluetooth Headphone products on offer, you can view the manual for this particular model here: Manuals
Hoping that helps, if so please click the 'Accepted Solution' button below this post.
All the best!
Hi Shay,
The links I provided earlier show you some of the manuals for this model however having checked the three on offer it seems the User Manual has yet to be posted.
Here's that link again in case you missed it above: STR-DN1060 Manuals
Admittedly these manuals don't really tell you much other than how to update the software or how to use the bluetooth. Incidentally if you buy headphones with the NFC feature you wouldn't need to pair them as shown in this manual.
Keep checking the above link, Sony will post the manual soon no doubt.
Hi MK Slinky,
If you have not yet found a manual for the 1060 I have one in PDF format from Sony uk support.
Hi there, I think you posted your reply to the wrong member, I'm not looking for any manuals myself.
I notice the member @shayfarrelly is though.
