My receiver keeps turning off and then a second later turns back on. The front panel display remains on. It happens when watching Sky and Apple TV. It doesn't appear to happen when TV is off and I'm streaming Spotify. It tends to happen when first used and then after 10 mins or so the problem disappears.
The product is two weeks out of warranty so I am hoping there's a simple solution.
Hi there
I think it might be best if you check all of the connections on the STR-DN1050 to see if any have slightly come loose. I recommend unplugging them and then re-inserting them again.
Thanks. I'll try that.
