As the title says, everytime i switch off and on the receiver, center channel volume configuration is lost and set to -10 dB.
European model (Sweden)
Firmware update
Speaker config: 3/2, no subwoofer
Two HDMI inputs used: BD (AFD Auto mode) and Video 1 (HD DCS mode)
ARC HDMI output to Sony EX500
Rille
Solved, kept forgetting center channel level at -0,5 db as auto calibrated. Raised to 0,0 db which is now remembered by the machine. Obviously a firmware bug, but the 0,5 db doesn't make a difference really anyway
