Hello i've had to unplug my str-dg820 av receiver and once it was wired back up i only have the front right/left and woofer working. I assumed the rest of the wires hadnt been reconnected properly but if i select E-Surround mode which enables you to listen to 2 channel sound over the entire range of speakers they work so the speakers must be connected. i cant understand why i only have 3 speakers working to begin with. i am using the amp with a ps3.
can anyone help pls ?
