Hello!
I have a BDV-EF200 and I have some problems if you can help me. The speaker cables are broken and because of this system does not start, it gives me an error or warning "push pwr protector". How can I solve this problem? I can say I somehow connected the wires, but I have not isolated and I have not related subwoffer because I have no input jack. It can work without it? The error can be fixed?
Thank you!
Hi there
The manual lists the following for that error message:
Now, if your speaker cable is broken somewhere...this becomes much difficult...Which cable/s are the problem. Also I cannot find any cables from the normal suppliers, therefore you will rely on Ebay. I have had a search on Ebay with no success for cables in the UK. The US lists them - however, for the cost, you might be better off with a new system.
Alteratively, search for the connectors themselves (the coloured connectors) and create your own cables with normal speaker wire.
