What is the best sound setting for playing TV movies with using my BDV-N7200W?
Is that Clear audio +, soundfield, cinema studio or music area?
Hi there,
Welcome to the community.
Hopefully one of the forum members will be able to help.
Best wishes,
M
Hi ljmvandam,
To be honest, there is no right answer to this question! This is because the sound fidelity depends on a few things like the quality of the input and more importantly, the space of the room itself which affects how your ears will perceive the sound. However, if you want to take a good bet, you can go with Clear Audio + as it automatically tries to adapt to the content to make sound as best as possible. So I'd say at least give it a listen.
Hope this helps.
Win_88
