Would love some advice.
Am fed up with the wires on our old panasonic dvd system and fancy a blu ray system at the same time.
Dont know whether to get a Blu Ray player and a sound bar or
Get a 5.1 system with Blu ray and wireless rear speakers.
What do you suggest and can you recommend some of the products - it isnt easy to tell straight away which have wireless speakers.
thanks
Hi there
The physical speakers in a 5.1 system are always better. But the pertinent question is - What is your budget range?
PS : A quick scan indicates that only one model from this years range has wireless rear speakers : BDV-N7100W (of which What HiFi gives it a 5* rating : http://www.whathifi.com/review/sony-bdv-n7100w )
Wireless Speaker Option
Soundbar (2.1)
Before committing, always do your research, to ensure that you get the right/best product to suit your needs.
