Hi folks. I wonder if anyone would be able to help.
My projector after turning on, the fans starting and light bulb starting but then switch itself off and Standby light blinks 4 times. Warning light no flashes it's off.
Any idea what's wrong?
Its a fantastic projector but unfortunately not working 😕
Thanks for your input
J
Hi there
I could only find the following 'blinks' which is in the standard user guide:
As this projector is part of the Pro range of Sony's products, please contact their PrimeSupport:
https://www.sony.co.uk/pro/section/contact-support
