I have an issue I play Dunkirk 4k blu ray and in some scenes they stopped like the disc is dirty but is new and blu ray player.
Anyone have the same issues please help me
Hi edgardo24,
Welcome to the community.
I’m just looking into this for you and will get back to you shortly.
Thanks,
Pascale
Hi edgardo24,
I think I've seen this before, there was a workaround the situation as follow:
- Select Setup on the Home screen.
- Select Audio Settings.
- Select BD Audio MIX Setting
- Set to OFF (Default is On)
Hope this helps.
Almou_10
