I’ve been having a nightmare trying to set up the AV receiver so it always defaults to playing HDMI sound out via just the AMP instead of AMP+TV. I can do this manually of course through the AMP menu, but want to find a way of saving this setting so it’s selected when turning on the amp. Any suggestions? I am using an Optima projector is that makes any difference.
Thanks so much,
Harry
Hi Harry,
I'll look into this and will update the thread if there is a possible solution.
Best wishes,
Sean
Hi Harry9966 ,
This depends on the connected device settings I believe.
Have you tried connecting ti to a TV and selecting the audio settings to be audio system only?
Cheers,
Rose
