Hi everyone
Does anyone know how I can attach these banana plugs to my STR-DN1080 AV Receiver? They won't fit in and If push too much it will definitly cause damage!
I watch a few Youtube videos and I undrestand in some AV Receivers the red/black plastics can be removed but it I'm not sure if this is the case with my AV Receiver!
Hello @sepehrbeckham,
you should be able to unscrew the red/black "fasteners" completely if I am not mistaken or you can unscrew them so far until you can fit the banana plug beneath it.
Why do you want to use the plugs anyways - simply cut them off and use the cable directly.
- Nic
Hi
I had exactly the same problem with these exact same plugs - that why I'm here. I put a tiny bit of soap on the tip and they did go in - very tight. Hope this helps.
