The soundbar is connected using HDMI arc and the TV is Samsung Q9.
My problem is that I have Virgin TV connected to HDMI 1. When I switch to the TV input on the soundbar I get the Virgin picture without sound. When I switch back to HDMI 1 on the sound bar it buffers and then takes me back to the soundbar menu and I have to press HDMI 1 from the on screen menu to get a picture.This is constant and a real pain, it`s anything other than a smooth transition.
Hi Fraz,
We will check into this and let you know what we find. Maybe some of our members will be able to advise too.
Best wishes,
Ed
Have you tried connecting all of the devices directly to the TV and having only the TV's ARC connection to the sound bar? This should completely resolve this kind of issue for you.
That seems rather odd. Do you have the latest software version installed [on everything]?
