hi All
is it possible to connect Sony HT RT3 home cinema to Samsung Curved EUJ6300 via bluetooth? Or the BT it is only for portable devices for short distance connections? I know there is optical Toslink connection, however I would prefer to minimize wires at home.
thank you
Hi there
The HT-RT3 is designed to connect to a TV via optical connections. Besides, I do not know if Sammy TVs can output audio via BT to a Soundbar. If you have the HT-RT3 already, just test it?
