Hi, I have a Sony BDP-S550 running the latest firmware (024) and it will not play newer Blue Ray discs such as Django. Anyone come across this problem? Or have a solution.
HI there
I can see that you are on the latest firmware, however have you tried doing a Network Update on the player itself (which must be connected to the internet)? I ask this, because that Firmware was in Feb 2011, but in the meantime other software updates may have happened in the meantime (that is not technically firmware)
Hope that helps?
