Hi All,
Last night I went to watch a program on I player. I couldn't get past the start screen. I then went to channel5 and was able to stream a program, normal bpm rate. I could also access all the Sony content. Then I lost the internet connection. I'm using a wired connection to my BT hub. All other devises were picking up their wired connections and Wifi. All diagnostics showed the internet connection to be good, except with the N200. I performed the reset, removed it from the electricity supply for a minute and treied to do a reset on the connections pages or so but......
I've had the machine for a year or two now.
I was strange that I was able to pick up some of the streaming options but not I-player, then I lost the connection altogether, any help would be appreciated
Hi there
It appears that BBC iPlayer is at fault and down at the moment. As I cannot use it on my TV either.
Thanks for the reply, I'm not an expert on these types or things but I'm surprised that I could access the other streaming areas untill I lost the connection altogether, maybe 20 minutes after I noticed the I-player issue. I was able to access I-player from my phone and Tablet though.
I cannot watch iplayer on my SMPN200 but I can watch other channels on it. I have had to start using my laptop to watch iplayer.
