Usinge a Win7 computer, connected via a home network to the SMP, using Serviio as the DLNA utility, I can play video/dvd files on my Panasonic LCD TV without any problems. Sound & Picture are fine. However, after I've played a file and then erased it from the computer, it still shows up on the SMP. Also, after updating Serviio, I now have a second entry for Serviio - new entry is active and old one is 'dead' but still in the menu. Can anyone advise how I can sanitise the on-screen menus on the SMP (as seen on the TV screen) to show only the 'live' video files that are on the computer? Is this a SMP issue or a Serviio issue or something else?
https://www.sony.co.uk/discussions/message/649610#649610
In terms of getting rid of older files, maybe set serviio to refresh the library quicker? The SMP will just display what its being sent by the server on the PC
thanks
thanks
Thanks, I'll pursue the Serviio route.
