Hello. I d like to help me out.
I have a new external usb drive (wd passport usb 3) that has a usb to micro usb cable, with movies pictures and music in it. my nettbook and my desktop computers recognize it and play fine.
When i connect the drive to the smp media usb port, i get the message that the external device is not recognized. Then in the media player menu it shows me 2 usb port icons. the first one has an X sign, but the second icon has the usb sign and under it writes LUN1. If i select this all the files play just fine!
is it a way to fix this?. its very annoying to have this error message all the time i open the media player
thanks and a happy new year to all!!
Dimitris
Try it by not using the USB, mine is a WD NAS with ethernet to my router. then wireless to the SMP. Works fine. Worth a try.
ok!
how you do this?
the cable in the WD is micro USB to USB, and on the back of my router there are 3 (10/100 Mbps) fast ethernet slots.
do i need a kind of adapter to change from male usb to ethernet?
And then will all the movies, escpecially the 1080p mkv will play smoothly wireless??
MY wirelless connection runs at 8mbps
thanks
Message was edited by: jojosjojos
i bought an external usb2 drive and the false error message from the smp stopped
it seems that the player does not support usb3!!
sony....you have also to fix this with a firmware update!:smileyangry:
