Hi All
Got the above blue ray player. Turned it on today but screen is a red square in middle of tv screen and all menus are corrupted.
Does player needs a firm ware update and if so is it possible to download onto a dvd and do it that way or is player for the bin?
Thanks
Are you sure is not the Cable?
Thanks for reply, tried a different cable but no better
