Using an audio cable. have connected amp to my xbr 75x95l to use the S-Center speaker function.
Sound is still coming out of my center speaker and not from the tv. is this correct or is the S-center speaker function not working?
Read page 30 of your paper manual (or look it up here):-
https://www.sony.com/electronics/support/res/manuals/5037/4af6af6c1b2257bc2f5bb37efc844332/50370283M...
and make sure you are doing all the things it says are needed to achieve what you want.
thanks. still got center speaker connected. obviously that is what i am doing wrong
How could it be possible if you disconnect your center speaker e used the same connection to the TV that it is still receiving a signal?
