I sold an old TV and mistakenly gave them the remote for my Home Cinema! There's a few similar-looking ones on eBay, but not the exact model. Does anone know if there are any other models that are compatabible with this model? It's about 10 years old. Thanks.
Thanks for the info, but both links are for the manual! Could you re-post the link for the parts please? Thanks.
Hi @Dollycat55, sorry about the mix up there. Here's the link:
https://uk.eetgroup.com/Guides/Sony
It's possibly worth calling to make sure you get the correct one. The number is 0333 241 9271.
Model number should be RM-ANP006, part number either 148012711 or 991099930.
Hope you find one!
Mick
