Friday 23rd May approx 19:00 attempted to turn on DVD recorder RDR-HXD995. Seemed reluctant to power on from remote (and when pressing power on on unit itself) as in UPDATE mode. Finally after switching power off at the wall a few times, managed to get it to respond. However when a channel is selected, it displays for a short while and then the screen goes blank. Also, a programme which was set to record, has not recorded.
Is anyone else experiencing this problem - is this July all over again or is it just me?
Any help/advise would be appreciated.
Thanks
The recent problems appear to relate to the transmission of the EPG.(Electronic Programme Guide) in an incorrect format for some SOny devices. Sony don't transmit this but an EPG supplier so whilst the machine says 'update' it isn't in the context of a program software update but a regular transmission that details programme schedules
****** UPDATE *******
Hi all
I have just received word that the problem has been fixed. Please do a 'hard reset' of your RDR recorder - Unplug the unit from the mains power on the wall, leave for 30seconds and switch it on again.
Thank you all for your patience.
Same here - problem still occurs! 😞
Thanks Quinnicus, I'm 'in France' at present.
I was going to say pardon my 'french' - forums would censor it out
Can you guys (jamesdeadman, paftrain) try once more please in regards to switching it off again (before I report back)
HI all
I have reported back that the problem is not fixed according to your feedback.
Cheers.
Hi all.
Sorry to be a pain - can someone please try a full retune (to UK) of their RDRs after a hard reset? Would be most appreciated.
Cheers.
