I have a Sony RDR-HXD970 serial # 4004304. This unit does not work: it displays ‘Welcome’ but will not accept any commands – not even a front-panel reset. There is a red clock which flashes next to the Welcome message.
Anyone have any idea how I can get this working again, or where to get it repaired?
If you cannot even reset it via the front panel, try unplugging from main for let's say one day. It should discharge the battery so maybe it will cancel the problem (if it's not an hardware one...)
Hi there
I dont think anyone on the forums would be able to answer that question unfortunately. Only the Sony repair centre could tell you the likely costs associated.
If you wanna try you may have fun reading the service manual, maybe it can help. Be aware that in order to operate the service menu you need a special remote or a programmable one (I used an Harmony one)...
I decided the unit was beyond my abilities to repair, so will put it on ebay for sale - spares or repair
