Hello,
I've connected the recorder Line 3-TV (HXD890) to my Toshiba TV Ext1 (32ZP38B). When the recorder is outputting Freeview it is not asserting the SCART, so the TV can auto-detect and switch to that input. I have to manually select Ext1 each time. I have applied a factory reset to the recorder (and then gone through Easy Set-up etc.) and loaded firmware ver 1.24, but no improvement.
When I play a DVD the SCART is asserted and when I connect cheap Freeview set-top boxes to Ext1 they are detected.
Is this a known design issue with the HXD890?
Thanks
Message was edited by: Henchman1
