My RDR HXD870 updates about 4 x per day which is normally fine but now it locks in to update which completely freezes the machine . When this happens the only way to release it is to hold in the power button for 7secs. I have tried a hard reset and a firmware update...both failed to cure it. Any ideas anyone please.
Just read the link pewrigh. They also contacted me via my facebook page. No explanation as to why it took them so long to respond though even if it is an EPG problem. I expect someone senior from Sony has been doing a bit of "encouraging" by the sound of it.
I did suspect that it might have been the 4G issue, so plugged in the 0800 device they posted out to everyone, that made the epg come back, but then it just went back into update again this morning,
So just wanted to say thanks for the advice, it worked, its a good job there are people like you out there to offer help. I hope that Sony come up with a resolve, its a pain having to manually put all my recordings back in, just hope the channels don't reschedule any programmes until Sony sort this out.
There could be a load of owners out there that are assuming that their machines are broken ...
SO it's back to square one this Morning after finally getting the "set to France fix" to work after 15 goes, what do I find this morning the machine is back and STUCK AGAIN! in "UPDATE" will this nightmare never end? and what are Sony doing about it would it be nothing followed by nothing? aren't these people supposed to be experts and aren't they supposed to test things before rolling them out? all very unprofessional.
What did yioudo.Mine is stuck on up date and has swallowed trhe 1.70 update cd and is dead! CD won't open to remove disc either.
Hi All,
before posting any further comments please read this thread
I have locked this thread in a hope that we can limit the number of thread so to avoid confusion & make it easier for users to find the latest information..
Please also note that the update the firmware solution at the begging of this thread is not a solution to the current (july13) issue
