My unit when Plugged into one TV , when the TV is brought on after being in Standby the Tuner will not work on the TV. power down tthe TV for a few moments and powere back on, it will then work fine, till the next time it is powered up from standby. On the other brand TV the same scenarioa as above but its not the tuner this time its the remote control appieres to not activeat the input mode menu. tuner and everthing else is fine!
Obviously the RDR HXD 870 is upsetting something on both TV's I am using HDMI inputs but the same apperes to happen on scart!
