I HAVE JUST PURCHASED A SONY HOME ENTERTAINMENT SYSTEM (MODEL NUMBER) DAV-DZ531W..
I AM HAVING DIFFICULTY GETTING SPEAKER STANDS,MY LOCAL SONY SHOP SAYS SONY HAVE STOPPED MAKING SPEAKER STANDS ALTOGHTHER??.I HAVE TRIED E-BAY BUT NOTHING MATCHES.CAN ANYONE HELP?
Welcome to the forum.
You could try your local service centre and see if they could order them for you.
http://support.sony-europe.com/repair/asc/asc.aspx?site=odw_en_GB
Otherwise maybe look for a compatible 3rd party accessory - maybe somewhere like richer sounds might have a stand which is compatible..
Thanks
