picture quality options
SOLVED
profile.country.IE.title
cornelius1
Member
Hi
Has the STR-DN-1080 a functionality, where you can select various picture qualities (see below- Denon 2400). I'm not sure if I keep the Sony, because there are many issues and the Denon seems to have more functionalities
Off (Default): No picture quality adjustment is done with this unit. Standard: The standard mode suited for most living room viewing environments. Movie: A mode suited for watching movies in a dark room such as a theater room. Vivid: A mode that makes graphic images for games, etc. brighter and more vivid. Streaming: A mode suited for low bit rate video sources. ISF Day: A mode suited for watching movies in a bright room during the day. ISF Night: A mode suited for watching movies in a dark room at night. Custom: Adjusts the picture quality manually.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Sean_Mc
Moderator
Hi Wannagat,
There's some information about selecting picture quality in the manual here. Hope this helps,
Best wishes,
Ed
2 REPLIES 2
Sean_Mc
Moderator
Hi Wannagat,
Best wishes,
Ed
cornelius1
Member
Thanks Ed,
Thanks looks good.
But does that only work with Sony TVs
