Hi
I am the owner of a pvr hxd890.
Does anyone know how you set the input password, so that you can setup skip and lock for certain channels? I have never had to use the password before and I have had the pvr for a number of years, so I have no idea what the password is.
I am currently having problems with recording bbc one - when I set it to series record, it defaults to channel 800 (and something) and then because there is no broadcast on the channel, it does not record. Looking at suggestions on one of the threads, it suggests skipping the channel, however it appears I need the password to do it.
thanks for any suggestions
It might be buried away in the user guide - http://pdf.crse.com/manuals/3295080121.pdf
Hope it helps.
Hope it helps.
