I have a KDL-46NX703 with a BDV-E870 and SkyHD box
The problem is that I can't automatically switch the audio input to the BDV between the Optical input (Sky) and the TV HMDI input.
By configuraing the BDV-E870 set-up I can switch the HMDI Audio Return channel to "OFF" or "AUTO"
The problem in "OFF" is that I can't override the Optical (DD) input if I want to use the TV features such as Internet content and stream music. The Optical is used and I only get the Sky audio channel.
There should be a way for the BDV to either automatically or manually switch between (i) the Optical input or (ii) the HDMI (TV) channel
Any suggestions??
Hi this is a common issue when Sky is involved, the main problem is the send audio down both connects all the time, so via HDMI you get PCM and optical you get DD, in an ideal world it would be the reverse and then the TV would work correctly, unfortunate;y there us no fix, until Sky make a box that has all the correct HDMI signals and settings. it will always confuse what is meant to be a simplified system.
Thank you for your response however I believe that your diagnosis is incorrect for a number of reasons:
Possible ways for Sony to resolve this incompatibility are:
This in-compatibility between state-of-the-art Sony devices and a standard Sky box is not acceptable.
I look forward to your response.
