Hi All,
I have a Bravia KDL-32V2500 which has 2 HDMI inputs on the back. Until today it worked perfectly with my V+ box giving me HD TV using just one of the HDMI inputs (AV4). Today I tried adding my PS3 to the set up, and although the PS3 is recognised by the TV if I unplug V+ and use that input, it isn't recognised going into the spare input via HDMI.
I have tried both the V+ & the PS3 in both inputs with swapping the cables in all directions and it seems that the 2nd HDMI input (AV1) is not recognised by the TV.
Is there something I need to set up on the TV menus that will solve this problem? I know I can get a splitter, but as the TV has 2 inputs, I would like to use both inputs.
Any solutions gratefully received.
Thanks, Gareth.
Message was edited by: gareth1967
Hmm - maybe try doing a full reset on the TV see if that helps, but normally they should just work.
Thanks
