Can anyone help?
Dav-DZ260 is not not outputting correctly. Symptoms are: No bass or cenral output when playing a dvd or outputting sound from an external device. Periodically the bass kicks back into life for a few seconds.
I have swapped the speakers and they both work when plugged into other speaked output ports. I have also tried unplugging the system for around an hour and a half and then re-activating it. Connections seem in good order.
Any other ideas?
Many thanks.
