Hi when connecting my ps4 pro to my xt3 soundbase on the hdmi 1 input it says my tv does not support hdr but if i plug the ps4 directly into the hdmi port on my tv its fine.
I am using a ps4 pro with a ht-xt3 soundbase with a sd85 55in tv and the hdmi lead is hdpc 2.2 compatable is there a problem with my sound base
Hi there
The current advice is to connect the PS4 Pro directly to your TV. The HT-XT3 does not support HDR pass-through.
