I have a Sony DAV-DZ830W which is about 3 years old but the sound from it from it is pretty good for what I need
However, the rear speakers are wireless & has an infrared sender thing which sends the sound to the rear speakers.
Anyway, when I was moving things around earlier, the wire was pulled from the back if the sender & now I have no rear sound!
Does anyone know where I can get a replacement sender as I have no idea what I'm looking for?
Always a problem with discontinued hardware.
You are looking for a Sony DIR/T1 - try eBay or Google ......
........ I have found one here but you may not like the price!!!
http://uk.eetnordic.com/product.aspx?id=A4718204A&path=Sony-DIR-T1-MACEL
....... Or even worse: -
...... Or cheaper on Amazon.com (USA Site) if you can arrange shipping here: -
http://www.amazon.com/Sony-A4718204A-TRANSMITTER-DIR-T1-SPEAKER/dp/B001DGQ97I
