Good Morning from the UK.
Bing a big football fan, I wish to use the "FOOTBALL" button so it sounds like I'm in the stadium, but my remote doesn't match the operations manual. There should be a "FOOTBALL" button on my remote, but where the manual says it should be there's "DISPLAY". So, how do I get the "FOOTBALL" mode on my home cinema system via my remote?
Is your Remote the RM-AH111E?
No, it's a "RMT-AH110E" I think, that's what's on the bottom of it.
Thanks.
You should ask where you bought the Soundbar.
@binkybearuk wrote:No, it's a "RMT-AH110E" I think, that's what's on the bottom of it.
Thanks.
Hi @binkybearuk
There’s your problem, according to the specifications it should be a RMT-AH111E. Your remote is for the HT-XT3 etc.
Thank you, I've ordered one.
