Installed and working. Also installed SongPal on my Xperia Z3. I want to do Auto Calibrate, but the meny is not active.
Can you clarify what you mean by the "menu is not active"?
Have you selected the correct Input on your TV which your receiver is connected too?
Have you opened the HOME screen on your STR-DN1060 in order to access the settings?
Please be aware that the onscreen menu (Home Screen) will only display if your TV is connected using an HDMI cable.
You can access the Auto Calibration feature from this home screen and then navigate to SETTINGS --> SPEAKER SETTINGS --> Auto Calibration.
Make sure you connect the supplied calibration microphone when performing calibration.
