Hello
#Wheres to begin
My Amazon Firestick seems to work in the television set smugly
But venturing on
Which is the best free view box to get started up with to go with this television.
My DVD player works also but Its fitting the television to the big Sky Free view Cable outside the block of flats that I am currently stuck with.
Which way is the easiest.......
Hi @Mr0verself I take it that you are aware that you "new" TV is over 10 years old and no longer updated by Sony.
Hey there, if you're gonna buy anything for that TV, make sure that's it's not high end like 4K for example as it'll never work on it.
I don't agree. I haven’t got anything 4K that wouldn’t drop to Full HD, like this set is, if 4K wasn’t supported.
And then, when @Mr0verself gets a hankering for something a bit more recent, he won’t have to replace anything he’s bought to use with this 2012 set because he restricted himself to what the set could do, instead of buying modern.
A Generous Ariel man came and set up a Sky Plus B I bought off ebay (bothy for 15 quid) thanks,
I think your right though
I`ll stay away from 4k
Hello Mr0verself, thank you for updating the thread! I guess you can mark it as resolved now?
