The two are interlinked by an HDMI cable. I have tried resetting the HDMI settings on the TV but this does not rectify the problem. At present I have to manually power on the home cinema system else the TV sound will default to using the TV speakers. Can this fault be rectified by changing a setting somewhere or is there a hardware fault with either the TV or DAV-IS10?
Hi could you please advise on the model of the TV and if HDMI control is enabled on both products
