Does the multi region BDP-S770 play both USA (region A and 1) and UK (region B and 2)
Hi
As with the implementation of region codes for DVDs, Blu-ray Disc players sold in a specific geographical region are designed to play only discs authorised by the content provider for that region. This is intended to permit content providers (motion picture studios, etc.) the ability to support product differences in content, price, release date, etc., by region. According to the Blu-ray Disc Association, "all Blu-ray Disc players...(and) Blu-ray Disc-equipped computer systems are required to support regional coding." However, "Use of region playback codes is optional for content providers (ie the Media)
Hi Any Player that has been modified for Multi Region, would be DVD only, you would have to check with the supplier as it is not supplied by the manufacture in this way.
