Hi!
My mobile projector MP-CD1 suddenly stopped working. What happens is that everytime I turn it on, it shows the blue "No signal"-screen for like half a second and then says "Shutting down..." and turns off straight away. And then the charge lamp starts blinking red until I hold the power button for a while to make it stop blinking.
I don't know anything special I did that made this problem appear. It seems like a behavior like this could occur if the battery was almost empty or if it was too hot in the room, but none of this is the case.
Anyone that have an idea of what could be the problem?
Hi there,
Have you tried a factory reset.
Best wishes,
M
