I used to be able to catchup on BBC programmes via iplayer on my Sony BDV-E880 player but the play button has gone missing and it no longer works. Can anyone help?
Hi, Have you tried updating the firmware and running a factory reset? This usually clears issues like this.
Thank you very much. That all seems to have done the trick. I am very grateful.
