After doing a factory reset on my zd9 I can to the setting of HDMI for the enhanced format when set the home screen going off and on and flickering
So checked were I had the HDMI lead on the TV, Which was in the HDMI 3 ARC slot so as I could have TV sound through my SDR-DN 1080, So I changed to HDMI 2 , Now when I switch on the TV and the X700 I now get a black screen and the words no signal detected , But when I put a 4K HD disc in the film starts great picture and sound
What have I set wrong???
I bought a new set of HDMI cables to the highest spec last month
Why when using the HDMI 3 ARC slot you can not set to the enhanced format
Help please
Just to let you know problem solved, This with the help from the Sony centre Alloa who said its most likely your HDMI leads but I have just bought new ones from Amazon, so I bought 2 new leads plus a UBPX 800M2, Pixelgen are the leads now all works fine, The new player is just great
To follow up tried the following from trouble shooting pressed stop then home and pop up this changed the output resolution and I get the home screen back however when I play a 4k disc I only get 1080 60p so no 4k,
change the resolution back to 4k no home screen, Have to hope when disc is inserted it starts ok , picture is great no problems very stable , so what am I missing???
Update
With the player set at 4k resolution and the TV set to enhanced a Blu-Ray disc will not play you get sound but no picture, then tried a 4k ultra disc (Kong scull island) best picture and sound I have with this TV and player, still no home screen
