Just got myself a KDL-40EX503 and i was looking at speakers to go with them.
Quite interested in the HT-CT350 sound bar so i can Bravia sync, but looking at the sony website, the TV is not listed as compatible with the speakers.
Does anyone know why?
I have bought the soundbar after foolishly reading on Amazon that it was compatible. It will fit under the TV if you are going to wall mount but if you then try to fit the TV back onto the stand (with the soundbar attached under the lower edge of the screen) the drop height to the base isnt high enough.
If you are happy to have the sound bar sat on your AV stand or are going to wall mount then everything else is great. Bravia Sync works like a dream and the sound quality is great.
I am trying to get hold of the bracket from the 703 model as this is a bit taller and will therefore allow easy fitment of the soundbar.
Hope that helps!
